SSO Configuration: Symmetric Folder and Keyczar
Ascherer17
We are working on configuring SSO for our ThingWorx 9.0 deployment and are following the steps in the online documentation.  I've successfully configured SSO for earlier versions of ThingWorx (8.x), but I've never quite understood what is going on in this step, "Create the symmetric Folder":
https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx%2FHelp%2FComposer%2FSecurity%2FSSO%2FCreateSymmetricFolder.html%23
- Is this "metafile" we create in the ssoSecurityConfig directory supposed to have a specific name?
- Are we supposed to use the "Keyczar" tool to do something?
- Does the 'keyczarKeyFolderPath' parameter in 'sso-settings.json' need to be set to the directory (...\ssoSecurityConfig\symmetric) or is it supposed to be set to the actual "metafile" (...\symmetric\mymeta.file)?
- Should I worry about this step if we're not using OAuth tokens?
The steps aren't entirely clear.
slangley
(To:slangley)
Hi @Ascherer17
As you know, a case was opened for this issue and as a result, the ThingWorx Help Center has now been updated with more detailed information to answer all of your questions.
Regards.
--Sharon
slangley
(To:Ascherer17)
Hi @Ascherer17
These are all good questions.  I am following up to get some answers and also get the Help Center documentation updated.
Regards.
--Sharon
slangley
(To:slangley)
Hi @Ascherer17
Regards.
--Sharon
