Any help on how can we implement any of the previous ideas?
Hello @slangley and thank you so much for your help.
In the end, we decided to use some custom CSS to change the scroll bar behavior and it's working.
Hi @JulianaGuerra.
You'll probably need to play around to get it just the way you want it, but if you scroll down on the Layout tab there are some additional options for Container Size. You can also try with a mix of responsive containers and panels. The Panel and Folding Panel widgets are legacy in the latest 9.0 release.
This information in the ThingWorx Help Center may help to provide some ideas around this. Be sure to look at the sub-topics as well.
--Sharon
Hi @JulianaGuerra.
I'm glad to hear that you found a solution. For the benefit of others in the community, please mark your last response as the Accepted Solution.
Thank you for your participation in our community!
--Sharon
