Hello, is there a way to make a mashup scrollable? Just like any other web page, when there is no more room for content, a scroll bar would appear and you would be able to scroll down to see more.
How do I do that, if that's even possible? Thank you.
I have created a page showing how to achieve this, it is available here:
Static mashups can do that
in 8.5 and up I believe if you use min width/height you can get that behavior as well I think.
Thank you, your point led me to a solution described below.
