Scrollbar on Grid-Widget
M4RC
Hi folks,
I have a problem with the vertical scrollbar on my grid widget (TWX version ThingWorx 9.3.8).
I have placed two grids vertically on top of each other, where the columns and their sizes partially overlap. However, when the vertical scrollbar is displayed on a table, the columns shift and it is no longer visually appealing.
The padding of the container (via Composer -> Layout) does not seem to have any effect on the grid.
Is there a way to use a kind of dynamic padding so that the area is reserved for a scrollbar?
Best regards
Marc
2 REPLIES 2
Hi @M4RC,
The Simple Solution will be to keep the first column at a Fixed width and the second column at an Auto Width; these settings can be done in the Configure Bindings in the Grid Widget.
Shashi Preetham,
+91 8099838001 | shashi@psptechhub.com,
PSPTechHub  ||  World of PTC Thingworx  ||  LinkedIn
M4RC
(To:pshashipreetham)
Hello @pshashipreetham ,
All my columns have a fixed width set by % (percent),
because the number of columns in both tables is different.
The only option I have in this case is to set the width of the last column to 'auto width'. However, this does not change the behavior of the grid.
Best regards
Marc
