Search in the Result to filter
Keerthivarman
I'm Trying to get filter the search result by using another search inside the result table in thingworx Navigate like in Windchill.
Looking for suggestion, how can i achieve this requirement or any workaround for this.
thanks,
keerthivarman
Hi @Keerthivarman
There are a number of filter functions that exist for infotables that you can apply to the results for further filtering within ThingWorx.  Are you trying to modify Navigate?  You can probably duplicate it for making your own custom changes if that is what you are referring to.
--Sharon
Hi @Keerthivarman
--Sharon
Hi @slangley
Are you mentioning about duplicating the OOTB entities for customisation?
Hi @Keerthi101.
Yes, you can duplicate the entities provided and customize for your needs.
--Sharon
