Searching for entry in Advanced Grid
yasmalik
9-Granite
Please Help me to filter it acc. to ware house product name and product id using query filter in advanced gridav.png
4 REPLIES 4
slangley
23-Emerald II
(To:yasmalik)
Hi @yasmalik.
Where is the data coming from?  Please provide more information around your use case so we can try to come up with an appropriate solution.
--Sharon
Data come from the database through service. I want to use query filter to filter the data acc. to selected row of the drop down list
slangley
23-Emerald II
(To:yasmalik)
Hi @yasmalik.
If we're understanding correctly, your data is stored in an external database.  You could therefore, build your query to return just the information you need.
We don't know what type of database you are working with, but we assume it would be able to run a select query to return only the fields and records needed.
Please provide more details if this does not answer your question.
--Sharon
slangley
23-Emerald II
(To:slangley)
Hi @yasmalik.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.  If you have further questions, please let us know.
--Sharon
