Service to authenticate and POST to external system
Re: Service to authenticate and POST to external system
Thank you all! After trying different things what worked for me was grabbing the cookie that I had received during authentication and setting it in my subsequent requests in the headers  as "Cookie" and not "Set-Cookie" (like browsers do), and then converting it to JSON payload, as below:
var json = me.Authenticate();
var cookie = {"Content-Type":"application/json","Cookie": json["_cookies"]};
var headers = JSON.stringify(cookie);
........ etc.......
I also believe this link might have some answers https://support.ptc.com/apps/solution_preview/solution/lang/presolution?lang=en&n=CS245905 but, unfortunately, I cannot see it at the moment, as I don't have support account. Still evaluating Thigworx...
Yuriy, here's what the resolution contains for that article, (BTW could you try creating an account on support.ptc.com under ThingWorx if you haven't already)
  • Cookies are sent to a service as a string of key-value pairs that are passed in as part of the HTTP Request headers.
    • They use the format "key1=value1; key2=value2;..."
  • In order to send a cookie to a service using the ContentLoaderFunctions.PostJSON service, a "Cookie" header needs to be defined.
Example Code:
// Define the headers that need to be sent with our service call // The "Cookie" header passes in a semi-colon separated list of cookies (attribute=value pairs) var headers = {"Cookie": "JSESSIONID=AB12397DCFB2342;myCookie=value123"};  var params = { headers: headers /* JSON */, url: "http://myserver.com/Services/MyService" /* STRING */, };  var result = Resources["ContentLoaderFunctions"].PostJSON(params);
Similarly, other headers can be added to the JSON request by adding additional attributes in the JSON object:
// Define all headers to be included with the request var headers = { "Cookie": "JSESSIONID=AB12397DCFB2342;myCookie=value123", "Content-Type": "application/json", "appKey": "a4823bdc48555aff" };  var params = { headers: headers /* JSON */, url: "http://myserver.com/Services/MyService" /* STRING */ };  var result = Resources["ContentLoaderFunctions"].PostJSON(params);
Thank you Sushant for all the help!
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________
