Hi all,
I'm passing an infotable from my parent mashup to the cell mashup using 'GlobalPropertyBinding' of the collection widget. I added in this property:
{"Events": "INFOTABLE"}
I added in my cell mashup the mashup property "Events".
But I'm not getting any data through... When there is in the parent mashup.
What am I doing wrong?...
Hello @TS_9588135 ,
Please check this article which helps to understand how to define Global Property binding
Toolika Dixit
Nederlands? of Belg?
Anyways back to english, the binding you specify should be the actual names of the parameter within your Dataset in the parent and the target mashup parameter name.
I can't tell exactly from what you are showing what the right names would be.
Hello @TS_9588135 ,
Toolika Dixit
Hi @TS_9588135.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
