Set infotable as Global Property Binding collection: no data...
TS_9588135
7-Bedrock
Hi all,
I'm passing an infotable from my parent mashup to the cell mashup using 'GlobalPropertyBinding' of the collection widget. I added in this property:
{"Events": "INFOTABLE"}
I added in my cell mashup the mashup property "Events".
But I'm not getting any data through... When there is in the parent mashup.
What am I doing wrong?...
tdixit
(To:PaiChung)
Hello @TS_9588135 ,
Please check this article which helps to understand how to define Global Property binding
Toolika Dixit
PaiChung
22-Sapphire I
(To:TS_9588135)
Nederlands? of Belg?
Anyways back to english, the binding you specify should be the actual names of the parameter within your Dataset in the parent and the target mashup parameter name.
I can't tell exactly from what you are showing what the right names would be.
tdixit
(To:PaiChung)
Hello @TS_9588135 ,
Toolika Dixit
slangley
(To:TS_9588135)
Hi @TS_9588135.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
