I am able to execute GetConfigurationTable service Where as SetConfigurationTable service when called inside service written by me is not setting all the Configuration values for Database/Mailserver Thing entity.Please verify from your end if there is any problem.
Can you please share your code if you are still having this issue.
Also after you SetConfigurationTables you must also run the service SaveConfigurationTables. You must do this even if the persist parameter is set to true.
What does your SetConfigurationTable code look like?
I usually use the Get first then update the table values and then Set it back.
After that do you call 'RestartThing'?
Yes I did called RestartThing, EnableThing services
Any update on this issue?
Could you share your code?
