SetPropertyValues in Custom Authenticator
tayyasamy
One quick question if any can answer immediately if possible.
I am following this link for authenticator, https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS244163&lang=en_US
Thing SSOThing = (Thing)EntityUtilities.findEntityDirect("SSOThing", ThingworxRelationshipTypes.Thing);
SSOThing.setPropertyValue("KeyName", new StringPrimitive(userName));
This code snippet i am trying to use in my custom authenticator also, inside authenticate function to update property, but i am getting error like,
"com.thingworx.common.exceptions.InvalidRequestException: Not authorized for PropertyWrite on KeyName in SSOThing" and no user name is displayed in the Logs for the custom authenticator.
ttielebein
(To:tayyasamy)
What does appear in the column of the Application log labeled "User", nothing? Polina Osipova​, does that mean that the System user is calling these services? How does the System user appear in the logs?
posipova
20-Turquoise
(To:ttielebein)
Since one cannot log in as a system user, and therefore, execute a service directly through the system user, a system user will never appear in the logs. When a system user is being used, a user column in the logs will show the actual User that invoked a service through the use of system user.
ttielebein
(To:posipova)
Ok, so we don't know what it means if no user appears in the logs then. Interesting... I believe I need to follow up with R&D about this issue
ttielebein
(To:posipova)
Oh, and thanks for your input!!
