Setting up Thingworx Analytics
drieder
Hello Everyone,
I am trying to deploy Thingworx Analytics with my Foundation Server. So I have the Foundation Trial 8.3 and the Thingworx Analytics Trial 8.3.2 installed.
According to this guide, I could simply set up Analytics by going to the Analytics Section in the Composer. There it says I should go to Analytics Builder -> Settings and choose a Analytics Server Thing.
Unfortunately when I do this, I can not chose a Analytics Server Thing but I am ask to enter Application ID, Application Key and Endpoint Host. I am not quite sure what to enter as an Application ID and Endpoint Host.
Foundation and Analytics are both installed on the same machine btw.
Any help is appreciated very much.
Best Regards,
Dominik
1 ACCEPTED SOLUTION
cmorfin
(To:drieder)
Hi Dominik
If you see Application ID, Application key and end point then you are certainly using an old version of the ThingWorx Analytics Extension.
You can check the version under Import/Export > Manage extension, you should have a 8.3.2 version for ThingWorx Analytics Builder extension.
The extension can be downloaded from the same place as the trial version : https://developer.thingworx.com/en/resources/downloads/analytics-trial-edition (You have a Download ThingWorx Extension button)
See also https://community.ptc.com/t5/IoT-Tech-Tips/Installing-ThingWorx-and-ThingWorx-Analytics-Trial-Edition-8-3/td-p/576047 to make sure all steps are properly done.
Kind regards
Christophe
2 REPLIES 2
cmorfin
(To:drieder)
Hi Dominik
Kind regards
Christophe
drieder
(To:cmorfin)
My Bad, thank you very much.
I downloaded the Extension from the Marketplace and there it was the newest version I believe.
Dominik
