We are working to address an issue with subscription email notifications. In the meantime, be sure to check your favorite boards for new topics.
Can we setup building Docker images in Windows OS? is provided scripts work in Windows?
Hi @vi1
Building of Docker images is only supported for Linux operating systems. The scripts have been validated on Ubuntu 16.04 and should work on other Linux operating systems that support Docker and Docker Compose. Note that PTC has not validated other systems.
Hope this info can help you.
BR,
Max
Hi @vi1
BR,
Max
Thank you for information. What is the way for Building of Thingworx Docker images on Windows OS?
Thanks&Regards,
Latha
Thank you for clarification.
Latha
