Share sample entity for grid dynamic configuration
KV_10974131
8-Gravel
Hello
Previously I got a link where i was able to get sample entities for Grid to utilize dynamic configuration. Can some one please provide the same or may be can share any sample entities to set columns dynamically.
Hello @KV_10974131
Also there is an article having example of creating intitutive Grid Dyamic Column. Kindly refer the link to access the article:
https://www.ptc.com/en/support/article/CS337864?
Kindly share if you have any further questions.
Bhawna
Hello @KV_10974131 ,
We have one article present in the Knowledge base explaining the Grid Utilization using dynamic Configuration. Kindly refer the below link for the same:
https://www.ptc.com/en/support/article/CS246332
Bhawna
Hello @KV_10974131
Bhawna
