Show File uploding status popup while uploading a file using file upload widget
Keerthivarman
How to show File uploading status popup while uploading a file using file upload widget.
Note: i'm using TWX9.1 so in the File upload widget there is not Upload Start event in it.
Please suggest some workaround for this.
Hi @Keerthivarman
UploadStarted event was added in the File Upload (Themable) widget in ThingWorx 9.3.4 and onwards. Before ThingWorx 9.3.4, no OOTB event can trigger when file upload starts.
if possible then upgrade your ThingWorx to 9.3.4 or later to use the themable File Upload widget.
Hi @Keerthivarman
Let us know your feedback on it.
Hi @Surya_Tiwari
Is there any workaround till that?
Hi @Keerthivarman
I have not currently worked around that but look at the below reference article for this feature was added at 9.3.4.
https://www.ptc.com/pt/support/article/cs370217
