Something must exist since you can see the connections window in the mashup builder. Try doing an inspect to see what is uses.
In a security scripter I created, i pull services from a mashup to apply security automatically (See the Tips section) so that basically reads the stored JSON figured out a mashup name and then the Things and Services mapped to it.
Hi @tallrain.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
