Hi all,
I'm trying to test a simple workflow task in flow, using the FTP utility.
My idea was to get connect to my ftp server, upload a text file from one directory, create a directory, and then download that file there.
The documentation doesn't have any examples and all that I'm able to do successfully is create a directory.
Does anybody have an example of how to do this or can anyone point me in the right direction?
The upload file action gives the following error.
I have tried all the different paths that I can think of.
Hi Bryan,
The file needs to be written first before it can be uploaded to the FTP server. Find an example below:
Find the simple workflow structure example below:
Find the Upload File connector details below:
The Upload File FTP connector is ideal for uploading files written during workflow execution. This explains why you were receiving Invalid path provided errors.
I hope you find this information helpful.
Emmanuel
Hi Bryan,
Did you try using copy service from file transfer subsystem and check if paths are correct.
Thank you,
Gautham
Yes i did try that.
I have also tried various other methods to but up to this point nothing has worked.
I have placed this into the failed experiment box for now and will return to it once I have at least something working.
Thanks for the reply.
Hi Bryan,
Emmanuel
Hi @BryanK.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
