Simple Query via OracleDB11 relational db extension returning empty rows?? Error occurred while validating HTTP header: If-None-Match
How do I check browser setting to make sure cookies are validating OK??
Len Niska, Does the DB thing shows connected? You can press F12 to open browser developer option to check more details about the error.
Also, please recheck if your configuration settings are correct.
Hi Len, to add further to what Ankit already mentioned what is the output for the service in which this query is executed? Is it a select query?
