Hi All
Hoping for some help on the Slider widget. I am busy developing a mobile mashup but am finding the Slider Widget too small (depth, Height) to be able to use it.
Anyone have any idea how I can edit the height of this widget?
Darryl
Hi Darryl, are you still looking for solution concerning this question? If i understand your question correctly, there's likely no option out of the box, however you can use that widget as a base and can create a custom widget, you can check the CSS styling for that widget at \\webapps\Thingworx\Common\dhtmlxSlider
