Unable to start Thingworx 8.3 after installation
avbee
I manage to get through all the steps in this guideline to install Thingworx PostgreSQL but cannot start it.
I use :
sudo service tomcat8.5 start
It returns:
Using CATALINA_BASE:   /usr/share/tomcat8.5/8.5.23
Using CATALINA_HOME:   /usr/share/tomcat8.5/8.5.23
Using CATALINA_TMPDIR: /usr/share/tomcat8.5/8.5.23/temp
Using JRE_HOME:        /usr
Using CLASSPATH:       /usr/share/tomcat8.5/8.5.23/bin/bootstrap.jar:/usr/share/tomcat8.5/8.5.23/bin/tomcat-juli.jar
Tomcat started.
And i check the port though fuser and top  no service was running or listen to port 8080 ( the port i use in platform-settings.json ). Also i tried to access http://ip:8080, returns nothing. No tomcat was running. (If its run, it will return something e.g 401.
Output for catalina.out:
Error: Could not find or load main class usr.share.tomcat8.5.8.5.23.webapps.Thingworx.WEB-INF.
FYI,environment setup:
Distributor ID:	Ubuntu
Description:	Ubuntu 14.04.5 LTS
Release:	14.04
Codename:	trusty
java version "1.8.0_131"
Java(TM) SE Runtime Environment (build 1.8.0_131-b11)
Java HotSpot(TM) 64-Bit Server VM (build 25.131-b11, mixed mode)
psql (PostgreSQL) 9.5.13
Server version: Apache Tomcat/8.5.23
Server built:   Sep 28 2017 10:30:11 UTC
Server number:  8.5.23.0
OS Name:        Linux
OS Version:     3.13.0-153-generic
Architecture:   amd64
JVM Version:    1.8.0_131-b11
JVM Vendor:     Oracle Corporation
Any suggestion how to solve the problem?
avbee
(To:avbee)
It solved.
I manage to solve by copying all the thing from the website. TYjhe problem is because /etc/systemd/system/tomcat8.5 service is in different format (indentation and such) when i copy it from doc. and webpage.
Thank you
avbee
(To:avbee)
It solved.
Thank you
