Hi
i set MQTT Thing
and i start mosquito broker
after week i can't receive data from MQTT Client
it was dis-connected about MQTT connect thing
I left Thingworx running and did nothing.
Why will the connection be broken?
Thingworx was running normally and only the Connect property of the Thing connecting to the MQTT Broker was false.
Why?
thanks
seonho Cha: There could be different reason like network issues, changes done on platform which could have an impact on MQTT configurations.
Could you please provide application and MQTT Broker log for reviewing the exact cause of issue.
-Durgesh
-Durgesh
i check MQTT connect error cause port was wrong...
thanks!
