Sorting infotable columns order
snehanjali
7-Bedrock
Hi All,
While using advanced grid, I have changed the order of the grid columns in "Configure Grid Columns". But while viewing the mashup, the order is not changing. This happened after I sorted the output infotable based on one column using  a service and passing it on to the grid.
Have anyone faced the same issue? Can any one help on this?
cmorfin
(To:snehanjali)
Hi @snehanjali
Would you be able to share some entities that reproduce the behaviour, that would help to investigate.
Also what exact version of ThingWorx are you using
Christophe
mgoel
(To:snehanjali)
@snehanjali
I have tried change the order of Grid columns. It works fine without  sorting service in Info table.
I am not sure about your custom service, would you be able to provide code for same? So that i can test.
Mohit
