I am trying to get the following to work in my application.
The issue I am having is that the ® is being converted to %AE in the URL then the mashup fails to load because there isn't a mashup with the name Reflector%AE
Is there a way to actually make this work as I am hoping?
If I manually edit the browser and convert the %AE back to ® the mashup loads correctly.
Hello Paul Baierl,
As you probably noticed, it's not recommended to use such special characters in the names of entities at all.
Just to test it, I've created a mashup with the trademark sign in the name. If I replaced the trademark sign with '%25C2%25AE', the URL is working.
OOTB Thingworx redirection (e.g. via Navigation widget) are working fine by default.
J.
Hello Paul Baierl,
J.
Thanks for getting back to me Jakub.
Yes, I realize this isn't recommended. I was asked if it was possible and wanted to make sure I had all of the information before reporting back to the project manager.
Thanks again,
Paul
