Hi @MS_12859766,
Combo Chart basically allows you to have multiple types of graph in a single chart, types such as bar chart and line chart.
See Help Center - Configuring Combo Chart.
If you have multiple series for the same chart type (bar or line for example), you can stack multiple series together. like the stacked bar chart in below Combo Chart.
Also, refer to article CS418796 for how to create stacked bar chart
Hi @MS_12859766,
So I can only stack barcharts?
Then this is not a solution I would need.
I think you can also stack line chart. Can you elaborate on the solution in your mind using graph to visualize maybe?
