State Panel in State Panel Anchor setting ignored
jbester
Good day,
I am experiencing an issue while upgrading old mashups from TwX 8 to Twx 9.1.6, updating the deprecated widgets.
We have used panels in panels quite extensively in TwX 8 to have center alignment. I have updated the deprecated panel widgets to state panel widgets, but although the same Horizontal and Vertical Anchor properties are present, they are being ignored.
Is there another setting I am missing that has changed in TwX 9?
Thank you,
Kind regards
jbester
(To:slangley)
Good day Sharon,
From my testing, it was all mashups with a state panel within a state panel so it is quite easy to recreate.
The easiest way we could get around this oversight in testing, and maybe it is the more correct way of doing it in the new version, Is recreating (or migrating) the deprecated mashup so that the layout option becomes available in the left panel and then using the layout settings as applicable (making static or aligning etc).
Johan
VladimirN
(To:jbester)
slangley
(To:jbester)
Hi @jbester.
Can you provide a sample mashup where this is happening?  If we can recreate it, we'll open a case with R&D for addressing in a future release.
--Sharon
jbester
(To:slangley)
Good day Sharon,
Johan
