State definition
krishnakomal123
State definition
In the attached screenshot,you can see String name,style definition for that particular string names which are configured in State definition.In this both String name,style definition are predefined.I am using this State definition in pie chart.I want to pass both string name ,style definition to State definition using service dynamically.Is it possible using thingworx ?If so,can you attach it as a zip file to get a better picture?
Hi @krishnakomal123
I'd recommend you check this post.
Christophe
Hi @krishnakomal123
If I get your question right, I don't think it is possible.
I do not see a service that allows to create a state definition programmatically.
There is one for Style definition but can't see one for state.
Christophe
krishnakomal123
(To:cmorfin)
Could you implement style definition using service.If so,please share zip file?
Hi @krishnakomal123
Christophe
slangley
(To:cmorfin)
Hi @krishnakomal123.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
