Static Mashup widgets not loading in Mashup Container
VaibhavShinde
i am using Static Mashup with Threshold Indicator widget but when i run this mashup separately i can see the widget at runtime, but when i call this mashup in other Mashup Container the widget is not visible. could you help me please.
thanks
1 ACCEPTED SOLUTION
Working after restarting twx.
thanks
Hello @VaibhavShinde,
What is your ThingWorx version? We saw similar issues on 8.5.0, most of them disappeared once we upgraded to 8.5.1.
/ Constantine
Hi ,
I am using Twx 8.5.2 version . any issue with this? but i see someone using same but its working there.
8.5.2 should be fine, really it's only 8.5.0 which had severe issues.
We use contained mashups extensively, and they work fine, so there must be something unusual about your setup. Can you try to create a minimal example which doesn't work and describe / share it here? Maybe you're using some extensions which break out-of-the-box behaviors?..
/ Constantine
thanks
