Steam Sensor Java SDK
adikumar
While running the steam sensor example of Java SDK (latest one Java-SDK-6-0-4-595), I am getting below error:
Exception in thread "main" com.thingworx.communications.client.things.exceptions.DuplicateCharacteristicException: Service already defined: GetSteamSensorReadings
at com.thingworx.communications.client.things.VirtualThing.createServiceProcessorsFromThingShape(VirtualThing.java:717)
at com.thingworx.communications.client.things.VirtualThing.initializeFromAnnotations(VirtualThing.java:667)
at com.thingworx.sdk.steam.SteamThing.init(SteamThing.java:93)
at com.thingworx.sdk.steam.SteamThing.<init>(SteamThing.java:78)
at com.thingworx.sdk.steam.SteamSensorClient.main(SteamSensorClient.java:67)
In this example, I also passed the arguments as ws://localhost:80/Thingworx/WS 625807eb-43ef-40b0-b68f-9f5c6f308bbd 1000 1 10.
I tried to debug it but was not able to run this example through eclipse.
Can anyone have tried this example? I am using the latest Java SDK from PTC support site. and the Java SDK file name is MED-61061-CD-055_M030_Java-SDK-6-0-4-595.
Aditya
adikumar
(To:adikumar)
In the SteamThing.java class, where the initializeFromAnnotations() method was called twice.
Once in the creation of the constructor and then again later. So, I removed the 2nd instance of the initializeFromAnnotations() method, and then it started working after compiling the code.
supandey
(To:adikumar)
Hi Aditya, can you confirm if there are no two services of same name as noted in the error GetSteamSensorReadings
adikumar
(To:supandey)
Hi Sushant,
Thank you for the response.
There are no two services of the same name. Please find attached below the code too.
If I am commenting the GetSteamSensorReadings service, then the same error I am also getting for AddNumbers service too.
Aditya
adikumar
(To:adikumar)
It is the Java SDK Java-SDK-6-0-4-595. The latest one.
adikumar
(To:adikumar)
