Step by step Document for Thingworx foundation installation on Linux system
SS_2318
9-Granite
I am new to linux system and looking for installation guide having step by step installation process. if any one have document please share here .
I have seen help center document but its high level.
@slangley
Rocko
(To:SS_2318)
https://support.ptc.com/help/thingworx/platform/r9.6/en/#page/ThingWorx/Help/Installation/Installation/install_java_and_apache_tomcat__rhel_.html#
This is a 38 step instruction to install the prerequisites and 18 step instruction to install ThingWorx manually.
https://support.ptc.com/help/thingworx/platform/r9.6/en/#page/ThingWorx/Help/Installation/thingworxfoundationinstallerforlinux.html#
This is a nine section document on how to install with an installer.
Both documents are in the main ThingWorx Help Center. I strongly disagree on the "it's high-level" statement.
Should you have issues installing with those instructions, it might be helpful to ask for the specific steps you're are stuck at.
8 REPLIES 8
Rocko
(To:SS_2318)
SS_2318
9-Granite
(To:Rocko)
Thanks Rocko for your response.
But here i am looking steps for Thingworx installation using Installer. please let me know any documents links or tutorial video.
Rocko
(To:SS_2318)
That's the second link I gave you, it doesn't get any more detailed.
SS_2318
9-Granite
(To:Rocko)
I want know which command need to be used to install thingworx with Installer package.
meaning any general linux command works or any spacific commands.
if you aware any command please suggest here
Rocko
(To:SS_2318)
That is literally the last line from the screenshot I posted.
SS_2318
9-Granite
(To:Rocko)
you mean to line   execute ThingWorxFoundationMSSQL-x.x.x-x86_64.run will start installation? in linux environment
Hello @SS_2318
It looks like you have some responses from a PTC Support personnel. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
ok Thanks for you valuable suggestion. I got steps to install on linux environment. Thanks for helping
