Step by step guide for "Configure PingFederate to Redirect User Login Requests to your IdP"
seanccc
I'm trying to integrate ThingWorx SSO with a 3rd party IdP system,  PingFederate acts as service provider to the IdP in this case if I understand correctly.
I'm referring to the link   Configure PingFederate to Redirect User Login Requests to your IdP   to config PingFederate.  It says I have to create two connections: IdP connection and service provider connection , but the page doesn't provide concrete steps.  PingFederate has lots steps and new concepts such as : "SP Adapter Instance" for the two connections ,  it's hard to complete all the steps with confidence.
Could someone provide a step by step guide for the configuration on PingFederate ?
Sean
1 ACCEPTED SOLUTION
c_lowy
(To:seanccc)
Hi @seanccc,
I'm afraid there is no step by step guide from PTC for the configuration on PingFederate.
Have you considered using the Ping Federate Automation Script for this configuration ? Here are some link around this topic :
c_lowy
(To:seanccc)
Hi @seanccc,
slangley
23-Emerald II
(To:seanccc)
Hi @seanccc.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
