Style Definition function not contains opacity adjustment option in TWX 8.3..
SOLVED
Level 8
hello all,
            Currently i am using ThingWorx 8.3 composer, in that the style definition function not consist of opacity adjustment of color details. in the previous version of TWX it was available . i dont know how to enable it.
kindly give me the answer for this problem.
attached the style definitions color picking popup.
Re: Style Definition function not contains opacity adjustment option in TWX 8.3..
I have just tested in 8.3.1 and there seems to be a new alpha-component in the color picker to change the opacity settings (from 0.0 to 1.0)
Hi @Sugumar,
You have to use the new composer to set the opacity. Exactly how @mneumann said.
Vinicius.
