Style theme for tabs widget
VamsiN
9-Granite
I am not able to create separate theme for tabs widget. When I click on create theme it is only buttons, text etc.. Is there any way to achieve this?
Thanks in advance.
2 REPLIES 2
TonyZhang
(To:VamsiN)
It appears you cannot create a Style Theme that contains specific styles only applies to Tabs widgets.
You can, however, to change Global Styles settings in Style Theme to define a high-level style that will also effect Tabs display. For example Labels and Dividers, but that will also make an impact on the elements style in other widgets.
You will need to select a specific Tabs widget in mashup builder and go to Style Properties panel to configure tab-specific styles for that individual Tabs widget if necessary .
Tony
You can, however, to change Global Styles settings in Style Theme to define a high-level style that will also effect Tabs display. For example Labels and Dividers, but that will also make an impact on the elements style in other widgets. slope game
Thank you for the clarification. That helps a lot!
