Has anyone else had a sudden problem where they are unable to use Advanced Grids because the FooterData property is acting up? We've been using these Grids for a few months now. Not only has there never been a problem, I've never had a to-do list item for a lack of FooterData. I did a quick search and found that I should just need to uncheck the box for the EnableFooter property. Unfortunately, I can't even find that. Does anyone have any suggestions?
Hi Ike@ACE ,
I am using 9.1 Version, and if you check the properties it is available.
Attaching a screenshot for your reference.
And if you are using some other version, kindly revert back.
Regards
Bhawna
Unfortunately, I'm on 8.5
Hi Ike@ACE
Can you please check the given link?
It is available in 8.5 too.
Kindly revert back if you are still facing the challenge.
Regards
Bhawna
There is actually no longer a problem for some unknown reason. We're not sure what caused it, but everything is fine now
