Suddenly the AzureIoThubConnector has stopped working!!!!
Re: Suddenly the AzureIoThubConnector has stopped working!!!!
Hi Dipika,
the URL is rigth.
I suggest you to Check one parmeter in server.xml in tomcat->conf->server.xml if you have this:
  <Host name="localhost"  appBase="webapps"
            unpackWARs="true" autoDeploy="true">
if unpackWARs is false, you have to stop Tomcat service, change false in true, then re-start Tomcat service, and try the Connector.
This solved my problem.
Bye
Hi Maurizio,
Thank you for your response.
I setup SSL / HTTPS on Tomcat with Self-Signed Certificate. After that while running the azure-iot.bat, it is not giving any error but as mentioned in the documentation, the below lines are not showing up.Untitled.png
My command prompt looks like this:
Can you please tell me what's the problem?
Thank you.
Look in the documentation:
bye
