THINGWORX 8.5.2 & AZURE Connectivity With AZURE IOT HUB CONNECTOR 3.0.0.20
Farouk-Louali
7-Bedrock
Hello Community ,
I’ve attached a PDF file containing all of steps , configuration files and command lines  which I have used on my instance.Use it as a guide as a complement to the Getting Started online help documentation and it should get you up and running faster.
Thanks & Regards,
geva
(To:Farouk-Louali)
Excellent work Farouk!!  This will certainly help many others around the world who have struggled with this challenging installation and configuration procedure.
Here is a related video that I made which goes over a few of the parts of the configuration and logging and does a demo of connecting a device to IoT Hub and ThingWorx.
Greg
Hi @Farouk-Louali.
Your participation and contribution to the community is greatly appreciated!
--Sharon
geva
(To:Farouk-Louali)
Greg
