Hello Community ,
I’ve attached a PDF file containing all of steps , configuration files and command lines which I have used on my instance.Use it as a guide as a complement to the Getting Started online help documentation and it should get you up and running faster.
Thanks & Regards,
Excellent work Farouk!! This will certainly help many others around the world who have struggled with this challenging installation and configuration procedure.
Greg
Hi @Farouk-Louali.
Your participation and contribution to the community is greatly appreciated!
Regards.
--Sharon
Greg
