TWX 8.5 streams or value streams for devices historical data?
LuisCabello
Hi everybody,
I have some dudes, I want to know what is the best practice for devices that I want record historical data.
I have Temperature/Humidity devices and I don't know what is the best practice. I have two questions:
1. Is it better to have streams as devices?
2. Now I have a value stream associated to a template for record historical data because I need temperature or humidity data, It's well done?
My objetive later is make a Time series chart with the historical data, what is the best option?
pd: please I know this article Difference between Streams, Value Streams and Datatables in ThingWorx  but I need to choose which is the best option when I have remote devices that will send to a broker the data and the broker will be comunicate with Thingworx.
Thank you in advanced,
Luis.
PaiChung
22-Sapphire I
(To:LuisCabello)
Standard practice is to log the properties into a ValueStream
3 REPLIES 3
PaiChung
22-Sapphire I
(To:LuisCabello)
And so, When you have to use a stream thing?
Thank you for reply.
Luis
PaiChung
22-Sapphire I
(To:LuisCabello)
Streams are used when you want to combine a specific set of data over time from different sources.
Also if you want to pre-aggregate time series data
And if you are looking to record data over time paired with other relevant data points (similar to point 1)
