TWX I use: ThingWorx 9.2.3-b189
I have this issue with bar char xaxis labels. Labels are cut and there is no option in bar chart widget to increase the size of xaxis label, like xaxis format.
That option is only available for yaxis
I would like to increase the size of of the label, to get the full name
I try also with web components but no luck so far.
example:
Problem solved I increase the width of property VerticalAxisMaxWidth.
