TWX platform installation problem (TWX 9.4.0/ Ubuntu/ MSSQL) => Tomcat fails to start after setup
AK_10557584
3-Visitor
for a test system we are trying a setup of the ThingWorx platform with a MSSQL database:
  TWX: 9.4.0 on Ubuntu 22.04, 5.15.0 kernel, Tomcat 9.0.58, installed from
      MED-61212-CD-094_F000_ThingWorx-Platform-Mssql-9-4-0.zip
  MSSQL: 15.0.4298 (development licence) on Arch Linux, 6.3.3 kernel
While starting tomcat an exception is thrown and thus TWX does not start:
Mai 26 11:25:13 ubuntu-22-04 tomcat9[104372]: Deploying web application archive [/var/lib/tomcat9/webapps/Thingworx.war]
Mai 26 11:25:20 ubuntu-22-04 tomcat9[104372]: At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
Mai 26 11:25:20 ubuntu-22-04 tomcat9[104372]: 11:25:20,473 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Could NOT find resource [logback-test.xml]
Mai 26 11:25:20 ubuntu-22-04 tomcat9[104372]: 11:25:20,473 |-INFO in ch.qos.logback.classic.LoggerContext[default] - Found resource [logback.xml] at [jar:file:/var/lib/tomcat9/webapps/Thingworx/WEB-INF/lib/thingworx-platform-common-9.4.0-b49.jar!/logback.xml]
Mai 26 11:25:20 ubuntu-22-04 tomcat9[104372]: 11:25:20,488 |-INFO in ch.qos.logback.core.joran.spi.ConfigurationWatchList@7a8f22d6 - URL [jar:file:/var/lib/tomcat9/webapps/Thingworx/WEB-INF/lib/thingworx-platform-common-9.4.0-b49.jar!/logback.xml] is not of type file
Mai 26 11:25:20 ubuntu-22-04 tomcat9[104372]: 11:25:20,522 |-INFO in ch.qos.logback.classic.joran.action.LoggerContextListenerAction - Adding LoggerContextListener of type [com.thingworx.logging.LogbackCustomLoggerContextListener] to the object stack
Mai 26 11:25:20 ubuntu-22-04 tomcat9[104372]: 11:25:20,976 |-ERROR in ch.qos.logback.core.joran.spi.Interpreter@3:88 - RuntimeException in Action for tag [contextListener] com.thingworx.exceptions.ConfigurationException: java.io.IOException: error trying to initialize Platform storage [setting: /ThingworxStorage/database]
Mai 26 11:25:20 ubuntu-22-04 tomcat9[104372]:         at com.thingworx.exceptions.ConfigurationException: java.io.IOException: error trying to initialize Platform storage [setting: /ThingworxStorage/database]
Mai 26 11:25:20 ubuntu-22-04 tomcat9[104372]:         at         at com.thingworx.system.configuration.PlatformSettings.getInstance(PlatformSettings.java:3640)
Mai 26 11:25:20 ubuntu-22-04 tomcat9[104372]:         at         at com.thingworx.logging.LogbackUtilities.loadLogbackConfiguration(LogbackUtilities.java:54)
Mai 26 11:25:20 ubuntu-22-04 tomcat9[104372]:         at         at com.thingworx.logging.LogUtilities.initializeLoggerContext(LogUtilities.java:440)
Mai 26 11:25:20 ubuntu-22-04 tomcat9[104372]:         at         at com.thingworx.logging.LogbackCustomLoggerContextListener.start(LogbackCustomLoggerContextListener.java:23)
Mai 26 11:25:20 ubuntu-22-04 tomcat9[104372]:         at         at ch.qos.logback.classic.joran.action.LoggerContextListenerAction.end(LoggerContextListenerAction.java:70)
Mai 26 11:25:20 ubuntu-22-04 tomcat9[104372]:         at         at ch.qos.logback.core.joran.spi.Interpreter.callEndAction(Interpreter.java:309)
Mai 26 11:25:20 ubuntu-22-04 tomcat9[104372]:         at         at ch.qos.logback.core.joran.spi.Interpreter.endElement(Interpreter.java:193)
Mai 26 11:25:20 ubuntu-22-04 tomcat9[104372]:         at         at ch.qos.logback.core.joran.spi.Interpreter.endElement(Interpreter.java:179)
Mai 26 11:25:20 ubuntu-22-04 tomcat9[104372]:         at         at ch.qos.logback.core.joran.spi.EventPlayer.play(EventPlayer.java:62)
Mai 26 11:25:20 ubuntu-22-04 tomcat9[104372]:         at         at ch.qos.logback.core.joran.GenericConfigurator.doConfigure(GenericConfigurator.java:165)
Mai 26 11:25:20 ubuntu-22-04 tomcat9[104372]:         at         at ch.qos.logback.core.joran.GenericConfigurator.doConfigure(GenericConfigurator.java:152)
Mai 26 11:25:20 ubuntu-22-04 tomcat9[104372]:         at         at ch.qos.logback.core.joran.GenericConfigurator.doConfigure(GenericConfigurator.java:110)
Mai 26 11:25:20 ubuntu-22-04 tomcat9[104372]:         at         at ch.qos.logback.core.joran.GenericConfigurator.doConfigure(GenericConfigurator.java:53)
Mai 26 11:25:20 ubuntu-22-04 tomcat9[104372]:         at         at ch.qos.logback.classic.util.ContextInitializer.configureByResource(ContextInitializer.java:64)
Mai 26 11:25:20 ubuntu-22-04 tomcat9[104372]:         at         at ch.qos.logback.classic.util.ContextInitializer.autoConfig(ContextInitializer.java:134)
Mai 26 11:25:20 ubuntu-22-04 tomcat9[104372]:         at         at org.slf4j.impl.StaticLoggerBinder.init(StaticLoggerBinder.java:84)
 The /ThingworxStorage directory exists and has tomcat:tomcat permissions:
drwxrwxr-x   2 tomcat tomcat       4096 Mai 23 16:25 ThingworxBackupStorage
drwxrwxr-x   2 tomcat tomcat       4096 Mai 23 16:43 ThingworxPlatform
drwxrwxr-x   2 tomcat tomcat       4096 Mai 25 13:38 ThingworxStorage
 On the ThingWorx server the platform settings were done and tomcat did run before TWX was added. The TWX installation itself was undergone up to topic #14 (https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Installation/Installation/install_java_and_apache_tomcat__ubuntu_.html#wwID0EIWQR), which fails (as described above).
The MSSQL-database is running and can be accessed locally and remotely with Linux- and Windows-clients. The database-structures were initialized and do exist now:
./thingworxMssqlDBSetup.sh -h mssql.kuraray.vm -r '<vdlv>'
./thingworxMssqlSchemaSetup.sh -h mssql.kuraray.vm -r '<vdlv>'
Any hints what to fix to get TWX up and running?
Kind regards
Arndt
Hello @AK_10557584
You can refer the following articles to resolve your issue here
https://www.ptc.com/en/support/article/CS321777
Please feel free to revert in case it doesn't resolve the issue.
Hi, thanks for the reply. The suggested article is solving another effect, but unfortunately not mine. In my installation I get no log complaints about erroneous configuration files. My installation does not use customized locations for <ThingworxPlatform>, <ThingworxStorage> or <ThingworxBackupStorage>. All configuration files do have the correct line endings (<LF> in this case). The platform-settings.json content is as follows:
administrator@ubuntu-22-04:~$ cat /ThingworxPlatform/platform-settings.json
        "PlatformSettingsConfig": {
                "AdministratorUserSettings": {
                        "InitialPassword": "<GEHEIM>"
                "ContentTypeSettings": {
                        "supportedMediaEntityContentTypes": [
                                "image/svg+xml",
                                "image/png",
                                "image/gif",
                                "image/bmp",
                                "image/jpeg",
                                "application/pdf",
                                "image/vnd.microsoft.icon"
                "LicensingConnectionSettings": {
                        "username":"<XXXX>@<XXXX>.com",
                        "password":"<GEHEIM>"
        "PersistenceProviderPackageConfigs": {
                "MssqlPersistenceProviderPackage": {
                        "ConnectionInformation": {
                                "driverClass": "com.microsoft.sqlserver.jdbc.SQLServerDriver",
                                "jdbcUrl": "jdbc:sqlserver://mssql.kuraray.vm:1433;databaseName=thingworx;applicationName=Thingworx;",
                                "password": "<GEHEIM>",
                                "username": "twadmin"
        "ExtensionPackageImportPolicy": {
                "importEnabled": true,
                "allowJarResources": true,
                "allowJavascriptResources": true,
                "allowCSSResources": true,
                "allowJSONResources": true,
                "allowWebAppResources": true,
                "allowEntities": true,
                "allowExtensibleEntities": true
The startup messages from tomcat are:
Mai 30 08:45:51 ubuntu-22-04 systemd[1]: Starting Apache Tomcat 9 Web Application Server...
Mai 30 08:45:51 ubuntu-22-04 systemd[1]: Started Apache Tomcat 9 Web Application Server.
Mai 30 08:45:51 ubuntu-22-04 tomcat9[136906]: NOTE: Picked up JDK_JAVA_OPTIONS:  --add-opens=java.base/java.lang=ALL-UNNAMED --add-opens=java.base/java.io=ALL-UNNAMED --add-opens=java.base/java.util=AL
L-UNNAMED --add-opens=java.base/java.util.concurrent=ALL-UNNAMED --add-opens=java.rmi/sun.rmi.transport=ALL-UNNAMED
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: Server Version:        Apache Tomcat/9.0.58 (Ubuntu)
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: Server built:          Jan 6 1970 15:09:28 UTC
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: Server version number: 9.0.58.0
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: OS Name:               Linux
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: OS Version:            5.15.0-72-generic
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: Architektur:           amd64
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: Java Home:             /usr/lib/jvm/java-11-openjdk-amd64
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: JVM Version:           11.0.19+7-post-Ubuntu-0ubuntu122.04.1
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: JVM Hersteller:        Ubuntu
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: CATALINA_BASE:         /var/lib/tomcat9
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: CATALINA_HOME:         /usr/share/tomcat9
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: Command line argument: --add-opens=java.base/java.lang=ALL-UNNAMED
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: Command line argument: --add-opens=java.base/java.io=ALL-UNNAMED
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: Command line argument: --add-opens=java.base/java.util=ALL-UNNAMED
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: Command line argument: --add-opens=java.base/java.util.concurrent=ALL-UNNAMED
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: Command line argument: --add-opens=java.rmi/sun.rmi.transport=ALL-UNNAMED
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: Command line argument: -Djava.util.logging.config.file=/var/lib/tomcat9/conf/logging.properties
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: Command line argument: -Djava.awt.headless=true
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: Command line argument: -Djdk.tls.ephemeralDHKeySize=2048
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: Command line argument: -Djava.protocol.handler.pkgs=org.apache.catalina.webresources
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: Command line argument: -Dorg.apache.catalina.security.SecurityListener.UMASK=0027
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: Command line argument: -Dignore.endorsed.dirs=
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: Command line argument: -Dcatalina.base=/var/lib/tomcat9
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: Command line argument: -Dcatalina.home=/usr/share/tomcat9
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: Command line argument: -Djava.io.tmpdir=/tmp
Mai 30 08:45:52 ubuntu-22-04 tomcat9[136906]: Loaded Apache Tomcat Native library [1.2.31] using APR version [1.7.0].
 Kind regards
Arndt
