[TWX9.0] questions about the new schedule chart widget
lbisax
I was testing around with the new schedule chart widget introduced in TWX 9.0 and had some issues with it:
I set custom colors in the infotable data within the service feeding the chart. But the colors in the legend didn't change. Is this behaviour intended?
Secondly I don't like that the bars change their height when you expand a bar. Is there a way to disable the detail view completely? I can disable the graph to deny any interaction but than i can't use the filter option in the legend.
If there is not such an option it would be handy in future releases to be able to disable this feature.
lbisax
(To:slangley)
I'm not using any custom CSS. I was able to change the colors for both graph and legend via the style properties of the widget. So my "problem" is solved. Thanks anyway
slangley
(To:lbisax)
Hi @lbisax.
Are you using any custom .css that may be affecting the legend?  Can you provide the mashup you're using for this so we can look into it further?
--Sharon
lbisax
(To:slangley)
