I found an article that says that teamviewer is now integrated into Thingworx.
( https://www.teamviewer.com/en/company/press/teamviewer-is-now-integrated-into-ptcs-thingworx/ )
I also found a manual on how to install it, but for that i need the teamviewer extension and I have no idea where to find it.
Does anyone of you know where i find the teamviewer-extension for thingworx?
For any third-party integrations like TeamViewer you will need to contact directly the creator of that extension.
The ThingWorx Marketplace is not hosting such extensions since quite a few years (it was doing that in the past though).
Did you check in PTC marketplace? If its available there, I have not checked though.
