When moving from Thingworx 8.x to Thingworx 9.x, I can see there are many changes starting from the database schema to widgets in the composer and performance.
Almost all the modules and subsystems are impacted.
I would like to know what has changed majorly in terms of product technology which has led to so many changes.
This is just to understand so as to continue development with better knowledge.
Release notes points to very specific cases.
Is there any technical documentation which can help us to understand this?
Aditya
The major change according to me is active -active support . So I found this articles which helps
https://www.ptc.com/en/support/article/CS327218
Please mark this as accepted solution if it helps for future community member.
Hi @amittal1.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
