The column index is out of range: 1, number of columns: 0
向郭
7-Bedrock
Dear everyone,
I stucked with the problem that input variable could not put into sql statement,Thingworx give error "
my sql statement like:
select EXTRACT(MONTH from TIMESTAMP '[[ddd]]');   //ddd is the input variable  ,Datetime type
if I put the ddd with '2016-12-01 08:40:00', thingworx will give error.
thank you in advance.
Thank you Mahesh ,I have solved the problem,just change the query into "select EXTRACT(MONTH from [[ddd]]::TIMESTAMP);" 。
I don't know why , just keep trying.
6 REPLIES 6
ankigupta
(To:向郭)
Hi Xiang Jing Guo​,
I hope ddd is the input variable.
Try following query:
select EXTRACT(MONTH from TIMESTAMP [[ddd]]);
input variable should not be in quotes.
It works fine for me.
I hope it helps.
Ankit Gupta
Dear  Ankit,
I tryed the query you mentioned above,but get the following error:
ERROR: syntax error at or near "$1" .postion 37.
I use the postgresql as the database .
Thanks anyway.
mlohokare
(To:向郭)
Hi Xiang Jing Guo,
Have you tried with adding "Date/Time stamp" pattern in your query?
Like 'dd-mm-yyyy, yyyy-mm-dd' etc.
In my scenario, I used as suggested by Ankit and added specific pattern and it works,
select * from "FOO"
where
to_date(START_DATE)
BETWEEN
to_date([[StartDate]], 'dd-mm-yyyy')
AND
to_date([[EndDate]], 'dd-mm-yyyy')
I will suggest, first try to run the query which you are looking for on your database and then replicate it on ThingWorx.
Hope it helps.
Mahesh Lohokare
ttielebein
(To:向郭)
Hey, if one of these answers helped you, do you think you could mark it as correct so other community users can more easily resolve similar issues? Thanks!
yes Tori,but I didn't find where to mark .
