The point in the LedDisplay widget is not displayed
amejia1
6-Contributor
The LED Display (by default) widget no longer displays the point, it shows a space instead of the point.  Someone knows why?
TW version used :  7.4.4
Thanks.
amejia1
6-Contributor
(To:amejia1)
The problem was only present when the language of the current user was in french. It was only necessary to change the comma by a dot for the "decimal" token in the french localization table.See screenshot attached here.ScreenshotLocalizationTableToken.PNG
mgoel
(To:amejia1)
Alejandro Mejia​ I checked this on my local TWX 8.0 version and seems to be appearing fine. PFA
There could be some issue with your particular widget properties. So, please share property details to review further.
Mohit Goel
amejia1
6-Contributor
(To:amejia1)
CRArko
(To:amejia1)
Hi!
Did changing the comma to a dot for the decimal point then resolve the issue?
If so, would you please mark that post as the accepted solution?
Thank you very much,
-- Craig A.
