The selected dropdown does not show whole height.
knakaya
Hello,   I am using List widget in the Dropdown view type.
Whole character is not shown When I set DropdownSlectedStyle Text size large(48px).
Does anyone know how to use Dropdown properly?
Nakaya
4 REPLIES 4
Hi @knakaya
Could you try changing the "TextVerticalAlignment" (and "RowHeight") properties of the List to e.g. 40?
This should give you a bigger container for the actual text displayed in the Dropdown's main element.
Cheers,
Michael
knakaya
(To:mneumann)
I can't find property named "TextVerticalAlignment" in List widget.
Where can I change it?
Which ThingWorx version are you using?
I've tried with 8.3.1 where the property is just above the Style Definition properties.
Maybe you can find it with CTRL + F searching for "TextVertical" - otherwise it might not be present in earlier versions of ThingWorx.
http://support.ptc.com/help//thingworx_hc/thingworx_8_hc/en/index.html#page/ThingWorx/Help/Mashup_Builder/Widgets/ListWidget.html
knakaya
(To:mneumann)
I'm using ThingWorx 7.4.
Is there another way to do?
Thanks for your reply.
