Hi all,
I have created a remote thing and it is connected to an Allen Bradley Logix 5500 controller via Industrial Connectivity (isConnected bit is true). I have configured and bound a few properties however, some are updating and are showing "quality: good" while others are showing "quality: unknown". See attached image.
The one that is of "good" quality was added first and maybe an hour later I added the others that are of "unknown" quality. I am still connected to my runtime and ALL configured values are changing/updating in the controller.
The property start type is "read edge value".
I am running version 8.4.0-b2013.
Any help would be greatly appreciated! Thanks in advance!
After creating and binding the new properties (quality: unknown), have you tried restart the remote device and reconnect?
You can stop the EMS/SDK/Kepware you 're using and restart it to reconnect, don't need to shut down the physical device. Let me know if it helps
I restarted Kepware and that did seem to correct the issue. Thank you for the tip!
There must be something that I am missing in the configuration though. Surely I shouldn't have to restart Kepware every time I want to bind a new tag. Any thoughts?
UPDATE:
I reinitialized the Kepware runtime again (attempt to make the tag quality "good") and this time it closed my connection to Thingworx. Now I am unable to connect to my runtime via the Industrial Connectivity Configuration application. I get a pop-up saying "connection not established".
The error is the following:
"3/21/2019 10:55:30 AM Error ThingWorx Industrial Connectivity\Configuration Connection attempt to runtime failed. | Runtime host address = '127.0.0.1:32402', User = 'Default User', Reason = 'This operation returned because the timeout period expired.'."
What could be the issue?
