Thing Worx Composer
RaulBernardo.PV
Thing Worx Composer
Is it possible to connect ThingWorx with PLC without using kepware?
If yes, what is the best way to do this?
Translated by the Community Moderation using Google Translate
É possivel conectar o ThingWorx com o PLC sem usar o kepware ?
Se sim Qual a melhor forma de fazer isso ?
Hi @RaulBernardo.PV
Based on my experience, once I used the MQTT extension to communicate with PLC ( which publishes data through MQTT )
If PLC has OPC Server configured. You can use Thingworx OPC Aggregator to connect with PLC
More information on OPC Aggregator :
https://www.ptc.com/en/support/article/CS279002
Article - CS321770 - Connectivity guidelines for ThingWorx OPC Aggregator (ptc.com)
https://www.ptc.com/en/support/article/CS307107
You can download OPC Aggregator from the PTC site under Thingworx Foundation family
/VR
Hi @RaulBernardo.PV
/VR
