Thing's property value is not being the latest of the logged values
muzzammil
How do i make the thing's properties to have latest of logged values?
Because, in general, when the properties are logged, they should possess latest of the logged values. I have assigned the value stream and 'QueryPropertyHistory' service returns me the historical data yet, the properties are not possessing latest of the logged values. How to resolve this issue??
3 REPLIES 3
PaiChung
22-Sapphire I
(To:muzzammil)
Most current value in your query should be the value of the property itself.
I would check the TimeStamp on both the historical and the property
You can use GetPropertyValuesVTQ for that
muzzammil
(To:PaiChung)
@PaiChung What i actually meant was, i just need the latest of the logged property values under properties and alerts tab in every 'Thing' entities, which i'm currently not getting
PaiChung
22-Sapphire I
(To:muzzammil)
those values should be in sync unless you had to go through some system restart or thingshape/thingtemplate update that reset the property values
