How do i make the thing's properties to have latest of logged values?
Because, in general, when the properties are logged, they should possess latest of the logged values. I have assigned the value stream and 'QueryPropertyHistory' service returns me the historical data yet, the properties are not possessing latest of the logged values. How to resolve this issue??
Most current value in your query should be the value of the property itself.
I would check the TimeStamp on both the historical and the property
You can use GetPropertyValuesVTQ for that
@PaiChung What i actually meant was, i just need the latest of the logged property values under properties and alerts tab in every 'Thing' entities, which i'm currently not getting
those values should be in sync unless you had to go through some system restart or thingshape/thingtemplate update that reset the property values
