ThingTemplate Service Calls - Things[ThingName] is not running
mattl1
7-Bedrock
I have a problem with calling services from a thing that uses a particular ThingTemplate.
I am creating the Thing programmatically:
var params = {
             thingTemplateName: equipmentTemplate,
             description: description,
        Resources["EntityServices"].CreateThing(params);
        Things[equipmentName].EnableThing();
        Things[equipmentName].RestartThing();
Which works fine, but when I try to call a service from that Thing:
Things[equipmentName].AddVisibilityPermission(params);
Then it throws a Things[equipmentName] is not running error.
This only happens when using one particular ThingTemplate as the 'equipmentTemplate', all other templates 'run' fine.
Does any one know why this might be happening? I can't find any permission issues, spelling errors or anything in that ThingTemplate. We did just upgrade to 6.5 - Would that have anything to do with this one ThingTemplate?
kramesh
7-Bedrock
(To:mattl1)
Do you know if the RestartThing is completing?. and if so; when the new Thing is added and it shows up in server; can you then run your visibility permission service?. maybe it's timing issue.....
kramesh
7-Bedrock
(To:mattl1)
mattl1
7-Bedrock
(To:kramesh)
The RestartThing should be completing, I can warn the Thing[equipmentName].name afterward.
The thing is removed when the service is called because I have it in a trycatch as to not create any ghost things. So it doesn't actually show up on the server.
Aanjan
(To:mattl1)
What Template is the 'equipmentTemplate' based on?
mattl1
7-Bedrock
(To:Aanjan)
Thanks for the help guys, it turns out it was a timing issue. A ThingStart subscription was being called, and I guess it didn't like that. Thanks!
